2000 Mitsubishi Montero Brake Lights
MITSUBISHI
MISSB71
I've checked the fuses and replaced bulbs but my break lights don't work on my 2000 mitsubishi montero. They will sometimes work for 15 or 20 minutes and then go back out. I don't know where to begin to look. My tail, reverse, blinkers, and flashers all work.
Jan 22, 2007 at 8:06 AM
BACKYARDMECHANIC
  • 337 POSTS
Try checking the brake switch which is located on the brake pedal. Sometimes these switches can be adjusted depending on the car. If not then you may have a bad switch. In this case you will need to replace the switch.
Jan 22, 2007 at 10:13 AM
Suggested Repair
Check the brake light switch on the brake pedal and adjust it if the vehicle allows. If adjustment does not restore the lights, replace the switch.
Conversation Summary
The owner of a 2000 Mitsubishi Montero reports brake lights that sometimes work for 15 to 20 minutes and then go out, despite checked fuses and replaced bulbs. Tail, reverse, turn signal, and hazard lights work. The expert recommends checking the brake pedal switch, adjusting it if possible, and replacing it if it is faulty.
