2003 Mitsubishi Lancer AC Stops Cooling
MITSUBISHI
D.MCKOWN57
air runs intermittent. will be cooling the car down then as driving along gradually stops cooling. turn system off and then back on and sometimes starts to cool and sometimes it dosen't.
2003 mitsubishi lancer evolution 60k miles
i have checked freon pressure and it is in the ok range.
Oct 22, 2007 at 1:05 AM
2CARPRO JACK
  • 11,533 POSTS
Could have a pressure switch or relay that cant hold the amperage for long and pops off after a short time
Oct 22, 2007 at 7:51 AM
Suggested Repair
Check the A/C pressure switch and relay, which may not hold amperage and drop out after a short time.
Conversation Summary
A 2003 Mitsubishi Lancer Evolution with 60,000 miles cools at first, then gradually stops cooling while driving. Cycling the system sometimes restores cooling and sometimes does not. Refrigerant pressure was checked and is in the normal range. The expert suggested a pressure switch or relay that cannot hold the amperage and opens after a short time.
