1997 Mitsubishi Montero crankshaft bolt.
1997 MITSUBISHI MONTERO
13,800 MILES • 6 CYL • 4WD • AUTOMATIC
DAVEHEDGER
I had a complete break job done 2 weeks ago and also 2 cam plugs replaced last week. This morning I started my car. The engine sounded fine, but the 'break light' and a/t light came and stayed on plus I have no power steering. I had it towed to the garage that did the cam plugs. The informed me that the crankshaft bolt had fallen off.
QUESTION: When replacing the cam plugs could anything have been touched regarding the crankshaft bolt?
I'm not a gearhead so I know zilch about mechanical stuff. I just want to make sure that the work I had done did not create the crankshaft deal.
I've owned the car since it was new and I understand there was a recall on the crankshaft bolt in I believe 2000, but I don't remember getting a recall for this item.
Whatcha Think?
Dave
Nov 17, 2008 at 9:37 AM
  • 31,937 POSTS
Hi there,
There is no reason to touch the crank shaft bolt, apart to yous it to turn the motor ( a normal practice) but this is in the direction to tighten it, so i think that it has failed on its own accord.
mark (mhpautos)
Nov 17, 2008 at 8:38 PM
