HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Mitsubishi
Montero
Engine
Timing Belt
1997 Mitsubishi Montero timing belt
BAPTISTE
MEMBER
1997 MITSUBISHI MONTERO
6 CYL
4WD
AUTOMATIC
10,700 MILES
Please tell me how to do the timing belt or tell me how to align the gears.
Friday, January 4th, 2008 AT 7:00 PM
BAPTISTE
MEMBER
Friday, January 4th, 2008 AT 7:01 PM
Please
login
or
register
to post a reply.
Related Timing Belt Content
1993 Mitsubishi Montero Timing Belt
I Cut My Timing Belt Off Because It Was In The Way. I Need To Get My Fly Wheel Off Now To Put A New Timing Belt On. How Can I Get The Fly...
Asked by
epearson11
1993
MITSUBISHI MONTERO
GUIDE
Timing Belt
Automotive combustion engines require either a timing chain or belt to keep the camshaft to crankshaft correlation correct as part of the design of the engine. A timing belt...
The Engine Did Not Have Spark
How To Check The Crankshaft Sensor For Montero Mitsubishi Engine 3.0 12 Valves.
Asked by
jose brandi
1997
MITSUBISHI MONTERO
1998 Mitsubishi Montero Engine Swap Proceedures
I Will Be Doing An Engine Swap On A Montero Shortly And I Have A Few Questions. I Am Fairly Mechanically Inclined (a Few Honda & Subaru...
Asked by
blaze45
5 IMAGES
1998
MITSUBISHI MONTERO
Montero Engine Swap 3.0 To 3.5
2002 Mitsubishi Montero 3.0 With 89,000 Miles 6 Cyl 3.0l Automatic 4 Wheel Drive 2002 Mitsubishi Montero Engine Swap Hi Dear Sirs, I...
Asked by
specialist
2002
MITSUBISHI MONTERO
How To Get The Crank Pulley Off
Trying To Get The Crank Pulley Off My 98 Montero Sport, You Can't Use A Duckfoot Puller Because There Are No Anchor Holes For Puller...
Asked by
Allen t
1 ANSWER
1 IMAGE
1998
MITSUBISHI MONTERO
VIEW MORE
Serpentine Belt Replacement Saturn Vue
Serpentine Belt Replacement Dodge
Serpentine Belt Replacement Mercedes Benz
