1996 Mitsubishi Eclipse ignition firing
1996 MITSUBISHI ECLIPSE
BDOGG0070
  • 42 POSTS
Electrical problem
1996 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic
the coil pack fires on cylinders 2 & 3 but not on 1 & 4. changed coil, same problem. Spliced wiresgoing into coil made 1 & 4 fire but not 2 & 3. I guess my question would be why would it only fire on 2 cylinders? I have tested the 3 wires going into the coil. there are 2 grounds and 1 hot the working side ground "pulsed" my finger when testing the other side shows power but no pulse. Please help.
Jul 21, 2010 at 12:04 PM
Try checkng the crankshaft positioning sensor this is the one that tells the computer what coil to fire.
Jul 21, 2010 at 12:09 PM
BDOGG0070
  • 42 POSTS
[quote:b420be0393="rasmataz"]Try checkng the crankshaft positioning sensor this is the one that tells the computer what coil to fire.[/quote:b420be0393]
I have thought of that but cannot locate it. I can find the camshaft position sensor but not the crank sensor do you know where it is located?
Jul 21, 2010 at 12:18 PM
Non turbo 2.0l above oil filter
2.4L left side of engine by crankshaft end
Jul 21, 2010 at 12:50 PM
BDOGG0070
  • 42 POSTS
Thank you! your advice was right on the money! can you tell me how to become a part of this website? i have been a mechanic for over 20 years and would like to be able to give advice as well.
Jul 22, 2010 at 4:13 PM
