After driving twenty to thirty minutes the car starts vibrating
DKDODGE1516
  • 22 POSTS
No it was the same thing loss of power misfiring and vibration.
Friday, December 13th, 2019 AT 3:41 AM
  • 109,755 POSTS
Was the crank sensor replaced as well?
Friday, December 13th, 2019 AT 6:08 PM
DKDODGE1516
  • 22 POSTS
Yes that has been replaced.
Sunday, December 15th, 2019 AT 12:31 PM
  • 109,755 POSTS
The only other thing I can think of for the cam sensor code is a stretched timing chain. Something isn't adding up as far as it misfiring when warm.
At this point, I would run a compression test to see if there is any indication of a timing related issue. Also, and I know it's a year old, I would remove the ignition module and have it tested. That could be the misfire.
Sunday, December 15th, 2019 AT 5:46 PM
