miss and nearly all power loss does not stall
150,000 MILES
NALU
intermittantly, all of sudden, there is a miss and almost complete loss of power. It clears when I turn off the engine and restart. It has gone from once in three days of commuting to every few miles. I pulled codes P0455 and P1506.
Jul 11, 2013 at 9:59 AM
  • 110,248 POSTS
P0455 Evap Emission Control System Leak Detected (Gross Leak/No Flow)
P1506 Idle Air Control Overspeed Error
I have to be honest, I don't see how either of those codes would cause this problem. Have you checked fuel pump pressure when it is happening?
Jul 11, 2013 at 12:22 PM
NALU
I didn't think the codes were causing the problem either, but they were the only codes present. I do not have a fuel pressure guage. Yesterday I cleared the codes (pulled the ground off the battery), today I drove about 70 miles before it lost power again. In the next 30 miles it happened two more times. Could it be the PCM?
Jul 12, 2013 at 10:28 AM
  • 110,248 POSTS
It could be related to the PCM, but I don't feel that is the problem. See if you can borrow or rent a fuel pressure gauge at a local parts store. Something is telling me you are losing fuel pressure which is causing the power loss.
Jul 12, 2013 at 12:30 PM
NALU
Got pressure guage, engine off 40 psi, engine running 30psi, have not been able to catch pressure when loss of power is happening, it's is happening about once in 100 miles.
Jul 14, 2013 at 11:57 AM
NALU
what could cause an intermittant loss of fuel pressure?
Jul 15, 2013 at 1:58 PM
  • 110,248 POSTS
It could be the pump is going bad
Jul 15, 2013 at 2:00 PM
