What do you have for engine size?
What you have for reading on the TPS is within spec
next step and what I would suspect is a fuel pressure and flow issue
need to have a fuel system pressure tested
fuel pressure should be with key on engine off above 60PSI
with engine running above 30PSI
SPONSORED LINKS
Thursday, August 20th, 2009 AT 5:43 AM
