it wont start. It wont turn over, or take a jump, but there is enuf juice to run the radio and windows. The battery is a year old and I just cleaned up the battery posts and cables
Sunday, December 7th, 2008 AT 3:54 PM
ZACKMAN
MECHANIC
Under the hood, check the ignition switch fuse 30A, inhibit relay, and under the dash fuse panel fuse #26 10A. If all operational, check your neutral safety switch. Check the cable from the battery to the starter motor. Make sure the connections are clean and tight. If yes, bench-test starter motor.
