will not start after re-timed
170,050 MILES
MRVANOVER
  • 6 POSTS
I have put the crank back to time mark the cams back to time mark i even put the distributor on on number one plug and the van will not start after putting on a new timing belt. What else is there i can do to get the van running again or what have i done wrong?
May 19, 2013 at 2:53 AM
JDL
  • 16,098 POSTS
Put number 1 cylinder at top dead center before lining up timing marks. Do you have cylinder compression?
May 19, 2013 at 3:26 AM
JDL
  • 16,098 POSTS
I meant to say top dead center of compression stroke.
May 19, 2013 at 3:31 AM
MRVANOVER
  • 6 POSTS
# 1 cylinder was at tdc before i lined up the rest of the timing marks. yes i have cylinder compression. is there something else that i need to do?
May 19, 2013 at 3:32 AM
JDL
  • 16,098 POSTS
Engine cranking, did you visually check for spark at the spark plugs? If you have spark everywhere, check fuel pressure.
Was the vehicle running before you worked on it?
May 19, 2013 at 11:41 PM
