1996 Mercury Tracer Wet Spark Plug
COOPERJODY
My car started to run like it was missing. So I checked the spark plugs and either #1 or #4 cylinder was wet around the end of the spark plug like it was not burning the fuel. I checked for spark and it was there. What would cause this?[/b]
Mar 1, 2006 at 5:19 PM
PEPPERMRJ
  • 1,158 POSTS
Start cheap and easy. Replace the plug. Next thought would be a plug wire. Try some fuel injector cleaner, it can't hurt anything and will help if your injector is leaking.
Good luck and let us know. :)
Mar 3, 2006 at 9:55 AM
Suggested Repair
Replace the wet spark plug first, then check the plug wire. Use fuel injector cleaner in case a leaking injector is causing the unburned fuel.
Conversation Summary
A 1996 Mercury Tracer with 127,500 miles began running as if it were missing. The owner found a wet spark plug on cylinder 1 or 4, suggesting fuel was not burning, but confirmed spark was present. The expert recommended starting with a new plug, checking the plug wire, and trying fuel injector cleaner if an injector is leaking.
