1992 Mercury Topaz Starter Stays Engaged
MUADDIB45
my car is a 1992 Mercury Topaz 4 dr passenger vehicle with a 2.3 L motor and 120,000 miles and I am wondering if I hooked the solenoid switch up wrong because I keep hearing the starter motor running while the car is running. Then when I shut off the motor to the car it sounds as if my starter motor is disengaging at the same time. Did I mishook a wire to the terminals somewhere on the solenoid switch?
Mar 23, 2007 at 6:59 AM
MERLIN2021
  • 17,250 POSTS
either that or the ignition switch is bad. the starter should only crank in 1 key position...start, after you let go of the key it returns to run position, your starter is either hooked up to crank in both positions,
or the solinoid or ignition switch is bad...you don't wanna know the third option!
Mar 23, 2007 at 7:19 AM
MUADDIB45
[quote:8b9765f6b6="merlin2021"]either that or the ignition switch is bad. the starter should only crank in 1 key position...start, after you let go of the key it returns to run position, your starter is either hooked up to crank in both positions,
or the solinoid or ignition switch is bad...you don't wanna know the third option![/quote:8b9765f6b6]
well it is a new switch and a new starter and I am just trying to find out how many wires are supposed to be on the top terminal and on the bottom terminal before I burn up a 7th starter on my car
Mar 23, 2007 at 7:31 AM
MERLIN2021
  • 17,250 POSTS
Jack I think you have 3 wires on this car there should be 3 posts or terminals... they are all different sizes so you don't put em on wrong. The real big one is the battery. try changing around the two smaller ones...
Mar 24, 2007 at 2:25 PM
Suggested Repair
Confirm the starter solenoid has three different-size terminals and that the large post is the battery cable. If the starter stays engaged in the run position, swap the two smaller wires. If the wiring is correct, check the ignition switch, since the starter should crank only in the start position.
Conversation Summary
The owner of a 1992 Mercury Topaz with a 2.3L engine says a new starter continues running while the engine is running and disengages when the engine is shut off, and asks whether the new solenoid is wired incorrectly. The expert says the starter may be connected so it cranks in both start and run, or the solenoid or ignition switch may be faulty. The expert adds that this car should have three different-size solenoid terminals, with the largest connected to the battery, and suggests swapping the two smaller wires.
