1990 Mercury Topaz Idle Sputter and Stall
JFRANK
I am a chef not a mechanic but anyway I have a 1990 Mercury Topaz with a 4 cyclinder motor when the car is idling or a very low speeds the cars spits and sputters and very often dies also when I try to start it I have to pump the accelerator pedal to even get it started. I need my car to get back and foth to work can someone please help me out thank you very much in advance for you help in this matter.
Mar 11, 2006 at 4:58 PM
PEPPERMRJ
  • 1,158 POSTS
How many mil;es?
Might be tune up time. What maintenece has been done? Fuel filter, air filter, PCV valve, plugs, wires, cap, rotor, O2, etc can all affect performance. Try some fuel injector cleaner also. I like chevron with techron.
Good luck and let us know. :)
Mar 12, 2006 at 8:01 AM
Suggested Repair
Check basic tune-up and maintenance items that affect idle: fuel filter, air filter, PCV valve, spark plugs, wires, cap, rotor, and oxygen sensor. Also try a fuel injector cleaner such as Chevron with Techron.
Conversation Summary
The owner of a 1990 Mercury Topaz with a 4-cylinder engine reports spitting, sputtering, and dying at idle or very low speed, and must pump the accelerator to start. The expert asks about mileage and recent maintenance, suggests it may be due for a tune-up, and recommends checking the fuel filter, air filter, PCV valve, plugs, wires, cap, rotor, and oxygen sensor, plus trying fuel injector cleaner.
