Either that or the ignition switch is bad. The starter should only crank in 1 key position. Start, after you let go of the key it returns to run position, your starter is either hooked up to crank in both positions,
or the solinoid or ignition switch is bad. You don't wanna know the third option!
SPONSORED LINKS
Friday, March 23rd, 2007 AT 2:19 PM
