1987 Mercury Topaz Jerks Into Second Gear
TALIS420
my 1987 mercury topaz with 150 000 km the car is somewhat reving to high but when the car reaches forty k and must change into second gear it jerks into the gear it does the same thing slowing down into second gear my thought was the transmission fluid but any input would be much appreciated
Dec 17, 2006 at 6:24 AM
CARUNDELL
  • 602 POSTS
[quote:497d7e0afc="talis420"]my 1987 mercury topaz with 150 000 km the car is somewhat reving to high but when the car reaches forty k and must change into second gear it jerks into the gear it does the same thing slowing down into second gear my thought was the transmission fluid but any input would be much appreciated[/quote:497d7e0afc]
Hey talis,
Definitely make sure the fluid is right up there! Also I'm pretty sure there is a mechanical linkage from the throttle to the trans. This is your "kick down", ensure that its free and you can move it by hand. If its binding, spay the pivots with penetrant and work it by hand until it moves freely. Let us know!
Chris
Dec 19, 2006 at 8:18 PM
Suggested Repair
Confirm the transmission fluid is at the correct full level. Check the throttle-to-transmission kickdown linkage for binding; it should move freely by hand. If it sticks, spray the pivots with penetrant and work the linkage until it moves freely.
Conversation Summary
The owner of a 1987 Mercury Topaz with 150,000 km reports high engine revs and a jerk when shifting into second around 40 km/h, both accelerating and slowing down, and suspects the transmission fluid. The expert advises verifying the fluid level and freeing a possibly binding throttle kickdown linkage with penetrant.
