Hello from Alaska
a pals car broke down. 1990 merc topaz odometer has stopped at 12300 miles. I believe it is a 4 cylinder but not sure as it is dark and cold out (sorry didn't pay attention.
Problem: I arrived to look at the car. started the car drove it and it seemed to work ok. Parked it, then put it into reverse. It didn't go.. I turned car off for approx 5 min. restarted and drove it up to approx 25 mph in parking lot. Its icy out (temp 35F) so I didn't go much faster. I backed the car into a space. put it into park. within 30 seconds tried to put into drive. Nothing. No noise. no movement of any kind. Engine seems to be running ok. No strange noises there. Fluid in on transmission dip stick doesn't seem burnt or burnt smelling. Any ideas would be helpful
thanks
Flash
thanks
Flash
Nov 26, 2007 at 6:15 PM
