1999 Mercury Sable No Fuel No Start
MERLIN2021
  • 17,250 POSTS
I have a 1999 Merc Sable 3.0 SOHC I drove to work with no driveablity issues, parked the car for 16 hours,
and then had a no start condition. Engine crank fine and has spark, Seems like there is NO fuel in the fuel rail, do not hear the pump run on key on, Inirtia switch is in correct position. Could the pump relay cause this? Or is the pump NG? Car was 74,000 Mi.
Fresh tune-up with new wires and coil pack.
Well I put in the fuel pump and stil no go, changed relay and thats not it...what am I missing?
I checked all fuses in the power distrbution box, all ok
Fuel filter changed 4,000 miles ago, After removing the old pump, I hooked it up to 12v and it works!
The new one in the car stil does not!
Mar 3, 2007 at 10:48 PM
BHUGG
  • 157 POSTS
You didn't say if you checked the fuse. It will be in the same box with the relay.
How about the fuel filter?
Good luck.
Let the forum know what happens. We like feedback.
If we help, vote for those who deserve it.
Mar 4, 2007 at 4:05 PM
MERLIN2021
  • 17,250 POSTS
Mar 5, 2007 at 8:27 AM
BHUGG
  • 157 POSTS
How about an inertia switch? I don't know where it would be on your Sable, but that might be it.
Mar 5, 2007 at 4:09 PM
MERLIN2021
  • 17,250 POSTS
Turns out the harness at the left front wheel well chaffed right through one of the wires!
Mar 6, 2007 at 7:29 AM
Suggested Repair
Inspect and repair the wiring harness at the left front wheel well, where a chafed wire interrupted power to the fuel pump.
Conversation Summary
A 1999 Mercury Sable 3.0 SOHC cranked and had spark but would not start after sitting, with no fuel at the rail and no pump prime on key-on. The inertia switch, fuses, relay, and recently replaced filter were checked, and both the old and new pumps worked on direct 12V but not in the car. The cause was a harness at the left front wheel well that had chafed through a wire.
