97 sable lean codes
DAVE1968
I recently tuned up my sisters 97 sable wagon, 130,000 3.0 DOHC. When I removed the upper intake I noticed that they were both filthy. I cleaned the surfaces with very fine emery cloth and the intake ports also. The car runs fine but sets 0170&0174 after about 2 weeks of driving. Could I have damaged something in my cleaning tecnique. I also used brake cleaner to clean some of the surface.
Please Help
Dave
Oct 6, 2007 at 6:15 AM
BMRFIXIT
  • 19,053 POSTS
[quote:0de956a9de="Dave1968"]I recently tuned up my sisters 97 sable wagon, 130,000 3.0 DOHC. When I removed the upper intake I noticed that they were both filthy. I cleaned the surfaces with very fine emery cloth and the intake ports also. The car runs fine but sets 0170&0174 after about 2 weeks of driving. Could I have damaged something in my cleaning tecnique. I also used brake cleaner to clean some of the surface.
Please Help
Dave[/quote:0de956a9de]
I don’t know why you would do that (brake cleaner)
Did you use a new gasket? You should
You may have a vacuum leak recheck the worked area for vacuum leak
Good luck
Let us know
Oct 6, 2007 at 11:20 PM
