1997 Mercury Sable Failed Smog Codes
STONE57
97 Merc Sable V6 DOHC 105,000 miles failed smog test due to Trouble codes P0761 Shift solenoid C Performance or stuck Off. Another code P1518 shows as well. Any ideas?
Aug 22, 2007 at 7:34 AM
2CARPRO JACK
  • 11,533 POSTS
The shift solenoid problem should be taken to a trans shop to be looked at.The other code is for an intake manifold runner stuck open, there are vacuum actuators that open runners in the manifold under hard throttle, either the vacuum diaphram on one is blown or the plastic bushing on the end is broken allowing the rod to fall out
Aug 22, 2007 at 11:13 AM
Suggested Repair
Have a transmission shop diagnose shift solenoid C for code P0761. For P1518, inspect the intake manifold runner vacuum actuators for a blown vacuum diaphragm or a broken plastic bushing that lets the control rod fall out.
Conversation Summary
A 1997 Mercury Sable with 105,000 miles failed a smog test with codes P0761 (shift solenoid C performance or stuck off) and P1518. The expert advised taking the solenoid issue to a transmission shop and said P1518 indicates an intake manifold runner stuck open, commonly from a blown vacuum diaphragm or a broken plastic bushing.
