Mercury Sable EGR Code DPFE Sensor
LORI HEBERT
I have Mercury sable my check engine light is on the code that comes up is the EGR Valve is malfunctioning. I got a resopnse that fords and known for the dpfe sensor going bad. Where is it located? What should I use to clean it? Thanks for you help :wink:
Apr 8, 2006 at 12:57 AM
PEPPERMRJ
  • 1,158 POSTS
Can't realy clean it. You can clean the EGR and it's port with carb cleaner and an old tooth brush. If that does not work check or have the DPFE sensor checked and replaced if necessary.
Good luck and let us know. :)
Apr 8, 2006 at 3:11 PM
Suggested Repair
Clean the EGR valve and its ports with carburetor cleaner and a toothbrush. The DPFE sensor generally cannot be cleaned; if cleaning the EGR does not clear the code, have the DPFE sensor tested and replaced if necessary.
Conversation Summary
A Mercury Sable owner has a check engine light with an EGR valve malfunction code and asks where the DPFE sensor is and how to clean it. The expert says the DPFE sensor cannot really be cleaned, recommends cleaning the EGR valve and ports with carburetor cleaner and a toothbrush, and says to test and replace the DPFE sensor if that does not fix it.
