1996 Mercury Sable Jerks With Codes
VERITASSAINT7
1996 mercury sable 200,000 OHV 3.0 U
the car randomly jerks and i got codes P0340,P0131,P0401,P0402,P1130,P1131.
P0401 = EGR flow insuffient
P0402 = EGR flow excessive
they are contradicting each other?
Sep 17, 2007 at 8:06 AM
MERLIN2021
  • 17,250 POSTS
No they are telling me that the EGR is sticking and not operating smoothly. Try pukking it of and using a vac pump, to check the operation,
P0340 Camshaft Position Sensor A Circuit (Bank 1 or single sensor)
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
P1131 Lack Of HO2S11 Switches - Sensor Indicates Lean
P1130 HO2S Circuit Low Variance Bank 1 Sensor 1 G C X
P1130 Lack Of HO2S11 Switches - Fuel Trim At Limit M
First problem to clear up is the EGR or EVR...reset light and test drive.
Sep 17, 2007 at 8:48 AM
Suggested Repair
Remove the EGR valve and check its operation with a vacuum pump. Address the sticking EGR or EVR first, reset the check-engine light, and test drive before chasing the camshaft and oxygen-sensor codes.
Conversation Summary
The owner of a 1996 Mercury Sable 3.0 OHV reports random jerking and codes P0340, P0131, P0401, P0402, P1130, and P1131, and asks why insufficient and excessive EGR flow codes contradict. The expert says the codes indicate the EGR is sticking and not operating smoothly, and recommends removing it and checking operation with a vacuum pump. The expert advises clearing the EGR or EVR problem first, then resetting the light and test driving.
