1999 Mercury Sable Coolant Lamp
MTA
Recently the Coolant Level check lamp has begun coming on and off intermittently. The coolant mix and fill level are good and the engine temp gauge does not register a warmer than usual indication. Any thoughts on what might be the trouble? Thanks.
Jun 30, 2006 at 3:13 AM
EPERRY
  • 21 POSTS
there is a sensor in you overflow bottle make sure to wires are still intack if they are then chances are your sensor is gone.
Jul 19, 2006 at 4:37 AM
MTA
Had new coolant bottle installed (sensor is integral to unit). Problem resolved. Thank-you.
Jul 20, 2006 at 3:09 AM
EPERRY
  • 21 POSTS
glad i could help.
Jul 20, 2006 at 10:06 PM
Suggested Repair
Inspect the coolant overflow bottle level sensor wiring for damage. If the wires are intact, replace the sensor or the bottle if the sensor is integral to it.
Conversation Summary
A 1999 Mercury Sable had an intermittent coolant level warning lamp despite a correct coolant mix and fill level and a normal temperature gauge. The expert advised checking the overflow bottle sensor wires and replacing the sensor if the wiring was intact. A new coolant bottle with an integral sensor was installed and the problem was resolved.
