1996 Mercury Sable Overheats
LARRY GARRETT
I have a 1996 Mercury sable wagon with a 3.0 V6 with 120k miles on it. The problem I have is that I have change the thermostat, cooling fans and flushed the system but, it still overheats when the outside temperature gets above freezing. Can someone help? The car runs well but, this makes being stuck in heavy traffic a nightmare.
Jan 30, 2006 at 12:10 PM
2CARPRO JACK
  • 11,533 POSTS
Do the fans work? Also have it chemical tested for a blown head gasket
Jan 31, 2006 at 8:56 AM
LARRY GARRETT
Yes, the fans are working properly. A quick question, if the head gasket was blown and /or leaking wouldn't I be expending coolant? Coolant level stays the same. Just a thought. Also, when on defrost is being used, a/c blows cold air out of defrost but is mixed with heat. Also, is there possibly a computer chip somewhere which might have an effect on engine temperature.
Jan 31, 2006 at 1:26 PM
MVANNESSJR
  • 223 POSTS
Engine temperature sensor....
But when I had this occur on my 92 Merc Sable it was due to a failed water pump. No circulation of the coolant means that the car will overheat.
Having it chemical tested will tell a lot more about the circulation of your coolant than just head gasket issues. Might be air in the system, no flow through the water pump, etc.
Feb 1, 2006 at 11:28 PM
Suggested Repair
Have the cooling system chemical-tested for a blown head gasket and circulation problems. Also check the water pump for lack of coolant flow, bleed any trapped air, and test the engine temperature sensor.
Conversation Summary
The owner of a 1996 Mercury Sable wagon with a 3.0 V6 reports overheating above freezing despite replacing the thermostat and cooling fans and flushing the system. The fans work and the coolant level remains stable. Experts recommended a chemical test for a head gasket or circulation issue and suggested a failed water pump, trapped air, or a faulty engine temperature sensor as possible causes.
