1993 Mercury Sable Car won't start
SEAKISSED
  • 1993 MERCURY SABLE
1993 Mercury Sable 6 cyl Front Wheel Drive Automatic
When I start the car it will not start. I have checked to make sure it is getting fuel and it is. I have also replaced the distributor cap along with the rotor. It started for 5 seconds then died out on me and I can't get it to start again.
Saturday, July 25th, 2009 AT 2:26 PM
JGAROFALO
  • 489 POSTS
If you have fuel, and the engine will not start, then the problem is most likely an ignition problem. Check for spark at the spark plug wires. Us an inexpensive spark tester.
There are many things that can cause spark problems. Among them:
Ignition module.
Sensor inside the distributor (PIP sensor)
Coil
Wires (primary) broken, chafed, or shorted.
Connectors not fully engaged or terminals loose.
Distributor not turning. This is usually caused by a mechanical problem with the drive gear.
These are some things to start checking. Keep in mind that I cannot fix your car over the internet. You must be my eyes, ears, and hands. I can only supply the knowledge to help you in diagnosis and repair.
Saturday, August 1st, 2009 AT 8:53 AM
