1993 Mercury Sable Car wont start!
S_KOWALCZYK
  • 1993 MERCURY SABLE
  • 6 CYL
  • FWD
  • 80,000 MILES
A couple of days ago I disconnected the battery to clean off some corrosion. I connected the battery back up and now the car wont start. Everything is tight.
I tried to jump the car. The first time I tried I was unsuccessful. When my car was connected with jumpers I would get the ding ding of the door being opened and I would get lights on the dash. When I turned the key I just got a little bit of a noise. It wouldn't start. I finally got it started somehow, and then when I turned it off I tried to start it again, I didn't get lights on the dash or anything. I let it charge for sometime.
I was only able to remove the negative terminal because the positive was too hard to get off. I did pour baking soda on it with water so I cleaned it some. I am just not sure what to do. When I hook it up to another car it will not start. I don't think it's the alternator or anything and the battery should be just fine. It just seems like whenever I cleaned it, something went wrong.
I will try to disconnect again and try to clean the other terminal. That is the only thing I can think of.
Monday, January 12th, 2009 AT 1:11 PM
DOCFIXIT
  • 18,828 POSTS
Yes need to clean pos term. Try using a screw driver to spread open term. End.
Monday, January 12th, 2009 AT 4:53 PM
S_KOWALCZYK
They were still dirty. Apparently when I cleaned them the first time some of the baking soda seeped into the inside with corrosion then dried.
Tuesday, January 13th, 2009 AT 8:29 AM
DOCFIXIT
  • 18,828 POSTS
Baking soda the best battery cleaner around. Good job so your good to go.
Tuesday, January 13th, 2009 AT 10:05 AM
