1997 Mercury Mystique/blown head gasket
1997 MERCURY MYSTIQUE
SARAHB
The head gasket on my car blew one day while driving on the expressway. I had it replaced but now the car won't start. Had a friend check the compression and coolant spewed from one of the cyliders. What could the problem be and how would I go about fixing it?
Jan 21, 2007 at 11:34 AM
MERLIN2021
  • 17,250 POSTS
who changed the gasket? Most important when you remove the head you must machine it so it's flat again. While the machine shop has it the also check for cracks! sounds like somebody missed one...just hope it's the head and not the block. If all propper machineing and checks were done, then someone goofed the gasket install. Maybe it was put in upside down? Sometimes a special sealant is required on head bolts.
Mar 5, 2007 at 5:25 AM
