Mercury Mystique Coolant Leak
OWNAGESOFT
When I pour liquid, or antifreeze into my car I can see it seeping out Under the engine, and it runs down the parts, and all over unto the ground. When I hit the Gas, it squirts out more. Is this the head gasket? I have tried about 5 diffrent Stop leaks, and it all just leaks out.... What can this be, and how much to fix/repair.?
Jun 23, 2007 at 1:52 PM
2CARPRO JACK
  • 11,533 POSTS
What kind of car, and where is th ecoolant leaking from, grab a flashlight and see if you can pinpoint the source of the leak. Other than that, it does sound like it could be a head gasket. Have the cooling system chemical tested for exhaust gasses
Jun 26, 2007 at 1:19 AM
Suggested Repair
Use a flashlight to pinpoint where the coolant is leaking. Have the cooling system chemically tested for exhaust gases to check for a possible head gasket problem. Stop-leak products have not held the leak.
Conversation Summary
The owner of a Mercury Mystique reports that coolant poured into the car seeps out under the engine and squirts more when accelerating, despite trying several stop-leak products. The expert says it could be a head gasket and advises locating the leak source and chemically testing the cooling system for exhaust gases.
