2001 Mazda B2300 Coolant Temp Sensor
MARLON354
I am trying to find where the coolant temp sensor is located on my 2001 Mazda B2300 truck.
Jan 22, 2006 at 4:37 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The engine coolant temperature (ECT) sensor is mounted on the lower intake manifold near the water outlet/thermostat housing, except on 2.3L and 2.5L engines. On the 2.3L and 2.5L engine the ECT is mounted on the water outlet/thermostat housing.
Thanks for using 2CarPros.com!
Feb 14, 2009 at 3:03 PM
Suggested Repair
On 2.3L and 2.5L engines, locate the engine coolant temperature sensor on the water outlet/thermostat housing. On other engines, it is mounted on the lower intake manifold near the water outlet/thermostat housing.
Conversation Summary
The owner of a 2001 Mazda B2300 asked where the coolant temperature sensor is located. The expert said the ECT sensor is on the lower intake manifold near the water outlet/thermostat housing, except on 2.3L and 2.5L engines, where it is mounted on the water outlet/thermostat housing.
