1998 Mazda 626 Overheating
BOO TWO
I am original owner of 1998 175 HP 626 ES with 50,000 miles. Recently drove and noticed temperature gauge all the way over to HOT. I read what the possible causes could be on other FAQs. Here's mine: It has been extremely cold here lately (below 32 F). If I try to drive it to the service center (approx. 5 miles away) what are the risks of the engine block cracking???
Jan 27, 2007 at 3:46 AM
COSMO
  • 347 POSTS
If its running in the HOT I wouldn't drive it anywhere.....better safe than sorry, have it towed.
What if there is no coolant, or if the t-stat is stuck closed, or the belts have come off?
If its running in the hot get it towed.
Cosmo...Mazda TEch
Jan 27, 2007 at 11:06 AM
BOO TWO
Thanks, Cosmo...let me be more clear. The therm starts out cold and after driving about 2 miles it is shifting over to HOT. Can I drive it to the repair center without incident?
Jan 28, 2007 at 12:31 AM
COSMO
  • 347 POSTS
If it takes that short of a time to get hot....I wouldn't drive it.
Cosmo...Mazda TEch
Jan 28, 2007 at 3:01 AM
Suggested Repair
Do not drive the car while the gauge is in the hot range; have it towed to the shop. Check for low or no coolant, a thermostat stuck closed, and drive belts that have come off.
Conversation Summary
The owner of a 1998 Mazda 626 with 50,000 miles reported the temperature gauge moving to hot after about two miles in very cold weather and asked whether driving about five miles to a shop risked cracking the engine block. A Mazda technician advised against driving it at all and recommended towing, noting possible causes such as no coolant, a stuck-closed thermostat, or missing belts. After the owner clarified how quickly it overheated, the technician again said not to drive it.
