1999 Mazda B2500 Dead Battery
Suggested Repair
Charge or replace the battery if it will not take a charge, and clean and tighten the battery cables. With a fully charged battery and the engine running, check alternator output at the battery; it should be 13.5 to 15 volts, and a lower reading means the alternator should be replaced. If charging is normal, test for a parasitic drain with a 12-volt test lamp in series between the positive cable and battery terminal with everything off, doors closed, and the hood light disconnected. A bright lamp indicates a short or drain.
Conversation Summary
The owner of a 1999 Mazda B2500 with 80,000 miles found the truck completely dead, with no interior light, radio, or headlights, and it would not jump-start. A six-month-old battery tested fine at one store and dead at another, and nothing had been left on. The expert said a fully dead battery may not jump, and possible causes include the charging system, a bad battery, wiring, or a short or drain. Tests require a fully charged battery, clean tight cables, an alternator output of 13.5 to 15 volts, and a parasitic-drain check with a test lamp.
