2000 Mazda Miata Battery Light No Power
NEDFORD
mazda miata
2000
85,000 miles
2.0L 4 cyl Fuel Injection
Q: the battery light in my car was on for awhile and a friend of mine told me this was because my alternator was going bad. i was lazy about getting it checked and then the car just died COMPLETELY, nothing, no power, nothing at all like the car has died. is this my alternator? if the alternator has dies, will the car act like a corpse?
Apr 17, 2007 at 2:29 AM
  • 75,988 POSTS
Because the alternator kill the battery-now you need a battery before we can tell that alternator is not putting out-maybe just a connection probably. The engine has to be running before we can tell the alternator is no good.
HTH-Good Luck
Apr 17, 2007 at 2:27 PM
NEDFORD
thanks, but u said alternator killed th battery, so we need new battery to check alernator. am confused. was it the alterator that killed the batery? what does the battery light on mean? can that mean alernator?
Apr 18, 2007 at 12:41 AM
  • 75,988 POSTS
[quote:ff5f2c17ac="nedford"]thanks, but u said alternator killed th battery, so we need new battery to check alernator. am confused. was it the alterator that killed the batery? what does the battery light on mean? can that mean alernator?[/quote:ff5f2c17ac]
When the alternator is defective it will not recondition the battery, therefore the battery loses its electrical pressure and nothing will happen whether your turn a key or hit a switch-nada
Also might be a sulfated battery refusing to take a charge.
Apr 18, 2007 at 6:48 AM
Suggested Repair
Install a known-good or fully charged battery, then start the engine and test alternator output and charging connections. A battery light can mean the alternator is not charging; a sulfated battery that will not accept a charge is also possible.
Conversation Summary
The owner of a 2000 Mazda Miata said the battery light stayed on, then the car died with no electrical power, and asked whether a failed alternator would cause that. The expert explained that a defective alternator will not recharge the battery, so the battery can go flat and nothing will work. A charged battery is needed before the alternator can be tested with the engine running; a bad connection or a sulfated battery that will not take a charge should also be considered.
