1977 Mazda 323 Battery Not Staying Charged
RWATS11
hi my mazda 323 1977 battery is not staying charge
thanks
Mar 12, 2007 at 8:31 PM
  • 31,937 POSTS
Hi there,
Check the water in the battery, all the plates should be covered, Check for loose or broken alternator belt, is the charge light staying on? have the charge rate of the alternator checked, check battery terminals are clean and tight, and if battery is over 3 years old have it load tested, these tests take only a few minuits each so ther should not cost the earth is find out what is the problem. One last thing make sure that things like the boot light is turning off, a current draw test will show if there is any current draw when there should not be. This can be done by am auto elect.
Good luck'
Mark (mhpautos)
Mar 13, 2007 at 5:35 PM
Suggested Repair
Check battery electrolyte so the plates are covered, inspect the alternator belt, confirm the charge light and alternator charge rate, clean and tighten the battery terminals, and load-test a battery older than three years. Also verify the trunk light turns off and have an auto electrician perform a parasitic current-draw test.
Conversation Summary
The owner of a 1977 Mazda 323 reported that the battery does not stay charged. The expert recommended checking battery fluid level, alternator belt and charging output, charge warning light, terminal condition, battery age and load test, trunk light shutoff, and a parasitic draw test.
