1992 Mazda 323 Right Blinker Out
SPOKANERJ
Mazda 323, 1992, 142000miles: Right blinker system is not working. None of the lights work, including the dashboard light and you hear a faster than normal clicking sound. This would indicate a problem with the flasher, but in that case the hazard lights would still work normally. If I turn on the hazard lights the same thing happens: Left side works, right doesn't. What's wrong?
Dec 14, 2006 at 4:28 AM
2CARPRO JACK
  • 11,533 POSTS
To start I would check all of the grounds and bulbs on that side of the car.Sounds like something is grounded/shorted out.Be sure the correct bulbs are in the sockets,could also be the bulb shorted internally.Have some new ones ready.Use a volt/ohm meter to test the bulb sockets to ground
Dec 14, 2006 at 8:16 AM
Suggested Repair
Check the right-side grounds and bulbs, and confirm the correct bulbs are installed. A bulb may be shorted internally, so have replacements ready. Use a volt/ohm meter to test the bulb sockets to ground for a short.
Conversation Summary
A 1992 Mazda 323 has no right-side turn signals, including the dash indicator, and the flasher clicks faster than normal. The same right-side failure occurs with the hazard lights, while the left side works. The expert recommends checking grounds and bulbs on that side, verifying the correct bulbs, and testing the sockets to ground for a short.
