1985 Mazda 323 Won't Restart When Hot
DENNIS SHAW
1985 mazda 323, 1.5lt engine, mileage 195000km, auto trans. Problem; car will start normally at first however when the engine reaches normal operating temperature and the car is turned off it will NOT re-start. The engine turns over but very slowly as though it has a flat battery, however the battery is brand new. The car has had a reconditioned head put on recently.
May 22, 2007 at 11:47 AM
  • 75,988 POSTS
[quote:fbc07867ef="dennis shaw"]1985 mazda 323, 1.5lt engine, mileage 195000km, auto trans. Problem; car will start normally at first however when the engine reaches normal operating temperature and the car is turned off it will NOT re-start. The engine turns over but very slowly as though it has a flat battery, however the battery is brand new. The car has had a reconditioned head put on recently.[/quote:fbc07867ef]
It sounds like your engine is binding due to excessive heat/overheating and also creating the slow crank.
Check your igniton timing could be off.
May 23, 2007 at 10:33 AM
Suggested Repair
Check for engine binding from excessive heat or overheating that causes the slow crank, and verify ignition timing, which may be off after the recent head work.
Conversation Summary
A 1985 Mazda 323 with a 1.5L engine starts normally when cold but will not restart after reaching operating temperature. It cranks very slowly as if the battery were weak, though the battery is new, and a reconditioned head was recently installed. The expert suggested the engine may be binding from heat or overheating and recommended checking ignition timing.
