1985 Mazda 323 miss firing
MADKA
Electrical problem
1985 Mazda 323 4 cyl Two Wheel Drive Manual
we just changed points condenser and leads
getting good spark from coil but no spark to plugs
set points with a feeler gauge to specs
but still no spark can anyone give me any advise must be something simple
cheers
Sep 28, 2009 at 5:24 PM
  • 75,988 POSTS
If you are gapping the points correctly are you on the camlobe high side and not the flat side. If the gap is correct-inspect the cap and rotor it has to go thru to it, to get the plugs.
Sep 28, 2009 at 5:31 PM
