1994 Mazda 626 Battery Keeps Dying
INDIKE RATNAYAKE
Recently I bought a Mazda 626 1994 2.5L car with 145,000 mileage. The battery is continuously dying. So I checked all the fuses for any short circuits but couldn’t find any. I replaced the battery twice but still the problem is there. When the battery is fully discharged I got a jump start but it seems that the battery is not charging even after 30 minutes of drive and once car was stuck on the road. So I have to charge the battery using a charger and keep the negative terminal disconnected when not running. Could you please help me with this?
May 21, 2006 at 5:30 PM
SDALTON19
  • 87 POSTS
sounds like you have a bad alternator stop buying batteries and get an alternator on that thing i hope this helps
May 25, 2006 at 4:36 PM
INDIKE RATNAYAKE
[quote="sdalton19"]sounds like you have a bad alternator stop buying batteries and get an alternator on that thing i hope this helps[/quote]
Thanks for your help. It worked really well.
Jun 2, 2006 at 2:41 PM
Suggested Repair
Stop replacing batteries and replace the alternator, which was not charging the battery while driving.
Conversation Summary
The owner of a 1994 Mazda 626 reported a battery that kept dying, would not charge after driving, and had to be disconnected when parked. Fuse checks and two battery replacements did not help. An expert advised replacing the alternator, and the owner confirmed that fixed the problem.
