1987 Mazda 626 Battery Dies Instantly
BENSCH
We have a 1987 Mazda 626. We live in North Dakota and we had a span of very low temperatures (-40). Druing that time the battery died on the car, or so we thought. We jumped the battery, but when started to drive it killed and then would not even turn over. We purchased a new battery, but the same thing happens and continues to happen every time we try to charge the battery. What is wrong with it and what do we do?
Mar 13, 2007 at 2:22 AM
2CARPRO JACK
  • 11,533 POSTS
check for a starter relay, it might have stuck
Mar 16, 2007 at 1:07 AM
HELLCAT18
  • 21 POSTS
Also check your charging system. The batteries may have been good still, but drained.
Mar 29, 2007 at 11:38 PM
Suggested Repair
Check the starter relay for sticking, and test the charging system for a drain that empties the battery.
Conversation Summary
A 1987 Mazda 626 battery died in extreme cold, then died again after a jump and would not crank. A new battery did the same after charging. Replies suggest checking a stuck starter relay and the charging system, since the batteries may have been drained rather than failed.
