Hey guys finally managed to get my cat off it's all broken up inside so def nackered but I changed a bad spark plug in the 1st cylinder which seemed to make a difference but last time the car started it cut out after about 2 minutes as it would not rev about 2,000 rpm with new spark plug 1,000rpm with old spark plug but now I have removed the cat and O2 sensor attached it will not start at all now and again chugs but I think I may have flooded it, tried to de flood by removing fuel pump fuse turning over and replacing Ect but no joy but it does get the smell of fuel when fuse is out as it it setting ride of some then on the last attempt to start I think the battery is getting low and lights faded then all the speedos went to full and back down?
Do you know why this is and and where I would go from here and maybe the best way to de flood a rx8 if I still can?
SPONSORED LINKS
Monday, April 13th, 2020 AT 12:57 PM
(Merged)
