2003 Mazda RX8 Engine starting problems when hot
TRAWEISS
Engine Mechanical problem
2003 Mazda RX8 Two Wheel Drive Manual
I have a 2003 RX-8 231bhp which has had starting problems since I bought it which are worsening. It has had new plugs and starter motor (spins faster) fitted by a main dealer who has now given up with it. The problem is that the engine starts fine when cold as the auto-choke kicks in. When the engine is fully warmed up though it can take 30 minutes of cool down before starting again. Before the main dealer gave up with it he did say the compression was a bit low but that they had submitted that to Mazda technic and they did not think it was a problem. Need to know if it is worth taking this to another dealer? If not then a recommended workshop in the UK north west. If the problem is compression then what options are available?
Apr 14, 2010 at 12:33 PM
RACEFAN966
  • 5,029 POSTS
OK I would see another dealer or trusted shop. Have them check the fuel pressure when it don't want to start and have them ohm the coolant temp sensor when it won't start. Now with the coolant temp sensor have them ohm it by simply unplugging it and ohm the sensor and get me the engine temp when they test it and get back to me with that info. Sorry I can't recomend a shop but I am in the USA. Thanks
Apr 15, 2010 at 1:39 AM
