white smoke and sputtering
RANDY4U
1980 Mazda RX7 70,000 original miles 1.1 rotary 12A This car starts up and runs ok, but once you get going and accelerating, it smokes. If i stop at a signal, when I take off, it completly covers the whole car behind me in smoke. If I get moving along at one speed steady, it does not smoke. It does look like water is in the oil and its pretty thin. It also sputters alot.
Thanks
Randy
Nov 16, 2007 at 9:35 AM
BLACKOP555
  • 10,386 POSTS
that is almost always a sign of a blown head gasket or a cracked/warped head.
perform a compression test, the lowest cylinder should be no less then 75% of the highest.
Nov 16, 2007 at 10:03 AM
RANDY4U
I appreciate your reply and I would have thought all those things true if this car had a conventional motor, but it is Rotary and does not have a head or cylinders.
Thanks
[quote:05d426e00d="blackop555"]that is almost always a sign of a blown head gasket or a cracked/warped head.
perform a compression test, the lowest cylinder should be no less then 75% of the highest.[/quote:05d426e00d]
Nov 16, 2007 at 12:19 PM
BLACKOP555
  • 10,386 POSTS
terribly sorry i overlooked that!
Nov 16, 2007 at 12:36 PM
LEDGE2EDGE
  • 9 POSTS
Best thing i could say is to get a compression test done, I had one 13b do that too me, found out that the block was cracked, letting in extra oil. hope you didnt get a cracked block.
https://images.2carpros.com/forum/automotive_pictures/119025_rx7_3.jpg
Nov 17, 2007 at 3:07 PM
