If you have fuel, air and spark then your timing is off. Phone around to see who can run a diagnostic on the ignition module. Then take it off and have it tested.
This is going to sound silly, but first reset your computer. Turn the key to the run position and disconnect the negative battery cable. Wait a few minutes, some say 30 seconds others 2 minutes. Leave the key in the run position and hook up the battery cable back up. Then try to start it.
After you change any electrical part do this. It resets your computer to the factory specs.
Dan
Wednesday, June 13th, 2007 AT 9:00 AM
