1990 Mazda RX7 Car was idiling rough no will not start
MRRONNIEW
  • 1990 MAZDA RX7
  • 4 CYL
  • MANUAL
  • 115,000 MILES
Have mazda rx7 and the other day it started idiling rough jumping from 1000rpm to about 2000rpm up and down no stop. During this time it all so made my convertible top not motor up or down or the ac fan not to blow like the car was shutting only certain things off. It did this then I shut car off then restarted and it continued then all of a sudden the idiling smoothed out and the electrical started working all again. Now this afternoon the next day car will not even attempt to start just clicks once with electrical drown down then nothing. I tested battery and is fully charged but car will just do nothing but all eletrical is still operating.
Friday, April 18th, 2008 AT 4:18 PM
2CARPRO JACK
  • 11,533 POSTS
Need to get out a meter and start testing for 12 volts. You have a bad connection somewhere and need to isolate it. Start basic and be sure everything looks ok (no obvious corrosion) and the connections are clean and tight. Test at the fuse block in the car, ignition switch, all around until you find out where the voltage is low
Saturday, April 19th, 2008 AT 8:39 AM
