1991 Mazda Protege Overheating at Idle
BHALE7904
The car is a 4 cyl 1991 Mazda Protege. This car has about 96,000 miles on it. It is overheating when at an idle or very slow traffic but does great on the highway. So far the radiator has been flushed and thermostat changed. The temp gauge was checked to see if it was faulty but it isn't. It appears to be circulating water ok but can't say for sure. There's no water on the outside of the engine or in the oil...what do we check for next? Any help is greatly appreciated. Myson bought it to take back to college and he is very mechanically challenged but it seems to have our local mechanic stumped....
Aug 18, 2007 at 6:52 AM
  • 75,988 POSTS
[quote:e707a8ff22="bhale7904"]The car is a 4 cyl 1991 Mazda Protege. This car has about 96,000 miles on it. It is overheating when at an idle or very slow traffic but does great on the highway. So far the radiator has been flushed and thermostat changed. The temp gauge was checked to see if it was faulty but it isn't. It appears to be circulating water ok but can't say for sure. There's no water on the outside of the engine or in the oil...what do we check for next? Any help is greatly appreciated. Myson bought it to take back to college and he is very mechanically challenged but it seems to have our local mechanic stumped....[/quote:e707a8ff22]
Was it bleed properly and fans coming On.
Aug 22, 2007 at 9:40 AM
BHALE7904
yes it was bled properly and the fan on the back side of the radiator is coming on. The temperature sensor was replaced, the radiator cap was replaced as well and when I had it out today it is still going up to the H on the gauge and staying there after just a few minutes of idling and being in city traffic but it isn't boiling over. There is no leakage to the outside that can be seen at all and absolutely no water/antifreeze whatsoever in the oil. Also it has no problem whasoever accelerating up to 65-70 on the open highway nor any problem pulling a hill so there is no loss of power...
Aug 22, 2007 at 11:56 AM
  • 75,988 POSTS
[quote:83c0071608="bhale7904"]yes it was bled properly and the fan on the back side of the radiator is coming on. The temperature sensor was replaced, the radiator cap was replaced as well and when I had it out today it is still going up to the H on the gauge and staying there after just a few minutes of idling and being in city traffic but it isn't boiling over. There is no leakage to the outside that can be seen at all and absolutely no water/antifreeze whatsoever in the oil. Also it has no problem whasoever accelerating up to 65-70 on the open highway nor any problem pulling a hill so there is no loss of power...[/quote:83c0071608]
Pull the thermostat out run it w/o it-is it still happening if so. Remove the Rad. cap start it up run it for 5mins. do you see the coolant swirling around in the radiator-
Also you can squeeze the upper hose, thermostat has to open-do you feel a strong flow going thru when you let go.
Aug 22, 2007 at 12:06 PM
Suggested Repair
Confirm the cooling fan and system bleed, then remove the thermostat and test whether idle overheating continues. With the radiator cap off, check for coolant circulation after a short run, and squeeze the upper hose to verify strong flow once the thermostat should be open.
Conversation Summary
A 1991 Mazda Protege with about 96,000 miles overheats at idle and in slow traffic but runs normally on the highway, with no power loss, visible leaks, or coolant in the oil. The radiator was flushed, and the thermostat, temperature sensor, and radiator cap were replaced; the gauge was verified and the system was bled, with the radiator fan operating. The expert recommends testing operation without the thermostat and checking for visible coolant circulation and strong upper-hose flow.
