2003 Mazda Protege High Idle and Vibration
CHRIS660
  • 7 POSTS
I'm having a few problems with my 2003 Mazda protege LX @ 44,500 miles.
1) After I start the car, and the car is still in park, the car is idling around 1500 - 1700 RPM's and a humming noise is coming out of the front end. The normal idle for the car is apprx. 700 - 900 RPM's
2) When the automatic transmission kicks in, it's shifting at a higher RPM than usual. Through low gears to high, it usually shifts around 2500RPM's. Now it's shifting around 3200RPM's.
3) When I accelerate over 60MPH the front end of the car begins to vibrate and shake. The weird thing is that it's random. It'll happen about 70% of the time when I go over 60MPH. I'm not sure if this is related to the previous problem?
Thanks for your help.
Dec 30, 2006 at 6:50 AM
COSMO
  • 347 POSTS
Have any repairs been done recently? Alos has anyone adjusted the throttle? Also what size engine do you have 16.L or 2.0L?
Cosmo...Mazda Tech
Dec 30, 2006 at 7:28 AM
CHRIS660
  • 7 POSTS
just scheduled maintenance that was done around 42,000 miles. (oil change) The problem started about a month after that.
No one touched the throttle as far as I know.
The engine is a 2.0.
Thanks
Dec 30, 2006 at 1:29 PM
2CARPRO JACK
  • 11,533 POSTS
HAve it scanned. Sounds like the Idle Air Control might be having some problems.Check for vacuum leaks any time there is a high idle condition. Does the front end only shimmy on the same stretch of road?Get back to me
Dec 30, 2006 at 11:54 PM
CHRIS660
  • 7 POSTS
[quote:72b6069333="2CarPro Jack"]Does the front end only shimmy on the same stretch of road?Get back to me[/quote:72b6069333]
Wow, it's funny you mention that because it always happens more on my way home from work than to work. It'll happen a few times on the way to work, but it always happens as soon as I get on the expressway on the way home from work. I'll go up the onramp, and as soon as I hit 60+mph on the expressway, the front end will vibrate. Then I stay at 60mph or below for the rest of the way home.
Thanks
Dec 31, 2006 at 5:22 AM
2CARPRO JACK
  • 11,533 POSTS
Have the front end looked at. Ball joints can do that as well as a few other things. Better safe than broke down
Jan 3, 2007 at 9:01 AM
CHRIS660
  • 7 POSTS
just thought I'd let you guys know incase anyone else had problems with this:
I took it to the mechanic and he said that the high idle and high shift was caused by a faulty water pump. It was leaking and that was draining my coolant, causing the high idle and high RMP's during changing gears.
The vibration at the front end was caused by poor tires.
And also, my battery was bad.
So I got a new battery, water pump, and 4 new tires. The water pump was covered under warranty.
The weird thing is that it didn't give me the high idle on startup when I left the dealership; however, after 2 days of driving, it is giving me a high idle again when starting the car.
But everything else is fine. Oh well, i guess back to the dealership for round 2.
Jan 12, 2007 at 6:58 AM
Suggested Repair
Scan for idle-control faults and check for vacuum leaks. Inspect the front end, including ball joints. A leaking water pump, worn tires, and a weak battery were found and replaced, but the high idle returned, so recheck idle control and vacuum leaks.
Conversation Summary
A 2003 Mazda Protege 2.0 with about 44,500 miles developed a high idle of 1500-1700 RPM, later shifts around 3200 RPM, and intermittent front-end vibration above 60 MPH, often on the same route. Experts advised a scan, idle air control and vacuum-leak checks, and a front-end inspection including ball joints. A mechanic attributed the idle and shift issues to a leaking water pump, the vibration to poor tires, and also found a bad battery. After those repairs the vibration was gone, but the high idle returned after two days.
