Thank you
Brendan.......
Pressure-test the cooling system and radiator cap, and do a block check. Also inspect for a bad water pump, blown head gasket, clogged radiator, collapsed hose, or faulty thermostat. Check the dipstick for a milky appearance and look for white exhaust smoke. With the ignition disabled, disconnect the upper radiator hose and confirm the pump pushes coolant out.
The owner of a 1995 Mazda Protege 1.5 with 108,000 miles still has overheating after replacing the thermostat and cooling-fan sensor; the fans now run normally. A reply confirms a radiator cap that cannot hold pressure can cause overheating. The expert recommends a coolant pressure test or block check and lists a water pump, blown head gasket, clogged radiator, collapsed hose, or bad thermostat as possibilities. They also suggest checking for milky oil and white smoke, and verifying coolant flow from the water pump.
