ANYWAY, if I buy an alternator do you think that it is something that my sons and I could do with a repair manual, and does it sound like this is my problem?
thanks for your time.
Have the battery tested first, including a free starting-system check at an auto parts store. If the battery is bad, replace it and then test the charging system; do not test the alternator with a dead battery, which can give a false bad-alternator reading.
The owner of a 1999 Mazda Protege says it increasingly fails to start and usually starts after a jump, and wonders whether the alternator is bad and whether she and her sons could replace it. Replies recommend checking the battery first and getting a free starting-system test, then testing the charging system only after a bad battery is replaced so a dead battery does not cause a false alternator reading. Dealer pricing and the advice to walk away from questionable repair quotes were also mentioned.
