1993 Mazda Protege Overheating
BRUTICE
  • 7 POSTS
hey there, i have a 1993 maza protege and im having some problems with my car overheating, not sure where exactily but there is a bubbling sound as if something is boiling everytime i drive my car somewhere, the sound seems to be comming from the anti-freez overflow tank, the onle thing that prevents it from doing that for a longer period of time is if i turn the heater on :s, not i cant exactily leave it on during the summer soo yeah if someone could get back to me asap i would verry much appreciate it, thanks!!
May 14, 2007 at 9:30 AM
  • 75,988 POSTS
[quote:e62161274b="Brutice"]hey there, i have a 1993 maza protege and im having some problems with my car overheating, not sure where exactily but there is a bubbling sound as if something is boiling everytime i drive my car somewhere, the sound seems to be comming from the anti-freez overflow tank, the onle thing that prevents it from doing that for a longer period of time is if i turn the heater on :s, not i cant exactily leave it on during the summer soo yeah if someone could get back to me asap i would verry much appreciate it, thanks!![/quote:e62161274b]
Replace the thermostat a cheap fix and then comeback or read below for your possibilities:
Try replacing the thermostat-not it do the following below:
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat,Clogged radiator,Fan clutch,Radiator electrical fan,collaspe hoses,water pump
Hope this help Good LUck
May 15, 2007 at 10:17 AM
Suggested Repair
Start with a thermostat replacement as a low-cost check. If overheating continues, block-test for combustion gases in the cooling system before pressure testing, then inspect the radiator, fans, hoses, and water pump.
Conversation Summary
A 1993 Mazda Protege overheats and makes a bubbling sound from the coolant overflow tank; running the heater delays the problem. The expert recommends replacing the thermostat first, then testing for combustion leakage into the cooling system and checking the radiator, cooling fans, hoses, and water pump if needed.
