1995 Mazda Protege Erratic Idle After Filter
1995 MAZDA
HALL5882
Changed the fuel filter on a 95 Mazda Protoget.
Now Idle is erratic and seriouse stumbles on accelleration. Have I got "air" in the system as someone told me, or bigger problems ?
Mar 11, 2007 at 7:02 AM
2CARPRO JACK
  • 11,533 POSTS
Air will usually purge out of the system. Be sure it is the correct filter and is installed properly, no pinched lines or the such
Mar 12, 2007 at 1:14 AM
COSMO
  • 347 POSTS
Yah I would hazzard a guess that there is something else wrong.
Those fuel filters WILL run both directions, although not sure how you could do it (only seen one person do it, but they had to really force it LOL)
Maybe take the fuel filter off and check to make sure there is good flow through it. What kind of filter was it, OEM?
Cosmo...Mazda TEch
Mar 13, 2007 at 7:20 AM
Suggested Repair
Confirm the fuel filter is the correct part and installed properly, with no pinched lines. Check that fuel flows freely through it. Trapped air should purge itself; if the idle and acceleration problems remain, investigate another fuel-delivery issue.
Conversation Summary
After replacing the fuel filter on a 1995 Mazda Protege, the owner reported erratic idle and serious stumbling during acceleration and asked whether air was trapped in the system. Experts said air normally purges itself and advised verifying the correct filter, proper installation, unobstructed lines, and good fuel flow, while noting another problem may be present.
