2000 Mazda MX-5 Low Beams Out
BAREN
Need helpp .. short on cash!
My 2000 maita, mx-5 LS with 56K mi,low beams suddenly quit working! My high beams and parking lights work. I've check both fuse boxes, under the dash and the other under the hood and ther are good! I replaced both bulbs last month. Any advice?
Oct 21, 2006 at 5:36 PM
  • 55,857 POSTS
There is a headlight relay that I think has gone out, here is a guide and a wiring diagram that will help you get the problem fixed.
and
Please run some tests and get back to us so we can continue helping you.
Cheers, Ken
May 23, 2017 at 5:07 AM
Suggested Repair
Test the headlight relay and its control circuit with a test light; replace the relay if it has failed.
Conversation Summary
The owner of a 2000 Mazda MX-5 reports that the low beams suddenly stopped working while the high beams and parking lights still work. Both fuse boxes were checked and the bulbs were replaced recently. The expert suspects a failed headlight relay and recommends testing the relay and related wiring.
