2000 LeSabre - where to find Hi/Lo Beam relay?
2000 ALL OTHER MAKES ALL OTHER MODELS
DBART1280
While driving at night my High beam headlights both went out. I flicked the Hi/Lo beam switch on the steering column and the low beams come on but I can't turn on the High beams. The problem seems to be a bad relay. Anyone know where it is located? Under the hood or under the dash?
Feb 19, 2007 at 9:07 PM
CHEVY22
  • 1,375 POSTS
the high beam relay is in the underhood fue box and should be marked there is also a possibility it might be the multifunction switch , most of the time it is check it out and let us know
Feb 19, 2007 at 9:22 PM
DBART1280
Thank you. I found the relay responsible. When I tap on it the high beams come on and stay on till I switch back to low. How do I remove the relay from the socket? It doesn't seem to want to pull straight out. It is p/n OMRON # 12088567.
Feb 20, 2007 at 6:10 PM
CHEVY22
  • 1,375 POSTS
its been in there a long time , make sure there isnt a clip and if not give it a yank , glad we could help
Feb 20, 2007 at 6:32 PM
DBART1280
Thank you once again. You've been a great help. I pulled that relay and swapped it with an identical one for the low beams and now the low beams don't work but the high beams do. I swapped them back again so at least the low works until I can find a new relay.
Feb 20, 2007 at 7:14 PM
CHEVY22
  • 1,375 POSTS
good deal,thanks
also i would like to say congrats , no only have you successfully diagnosed your vehicle you also reverse diagnosed it without actually buying parts ,
just what i would have done , good job , pat yourself on the back
Feb 20, 2007 at 10:03 PM
